Weird Timing on a F
Near Madison, WI
Website
www.fjforty.com
Is there always a BB on the flywheel to set the timing by? I finally got a timing light and tried to set it and in the window I am seeing numbers??? :confused:
I had to put the clamp on the last cylinder spark plug wire (rear most cyl.) to see anything in there at all. Hmmm, I thought it was suposed to go on the #1 cylinder. I set it to the number "4" which showed in the window and it seems to be running fine now. So is this normal???
The cruiser is running great now because I just rebuilt the carb and reinstalled it. I just want to make sure the timing is correct. BTW This is on the stock F engine in my 69 FJ40.
yeah there should be a BB, but it might have come off, still should be a hole where it was.
yes clamp goes on #1(closest to front) wire
but the rest of your post lost me, #4 in the window? no 4 in my windows.......just a BB and a line
Somebody must have put on some sort of altered flywheel. Never heard of numbered flywheels.
I have never ever seen a numbered toyota flywheel. Or any numbered flywheel now that I think of it...Having the timing gun on the wrong wire is definately gonna alter your results...Did you disconnect vacuum from the carb to the dist and plug the ports?
I had never seen numbers on a flywheel before either. Hmmm, I don't know what's up with it either.
I did take off the vacuum advance to set it.
why would the light not work on plug wire #1. I had to rotate my flyweel by hand untill i could see where the BB had been, then i marked it with yellow chalk, there was so much rust of the flyweel to see it other wise.
While we are talking about timing an old F is it supposed to be at the line or at the BB? I am currently timeing it with the vacuum conected. If I time it with it disconected and plugged it runs horribly and misses like mad when you punch it. Mine is a 71 F. It seems to run better if I time it with it connected.
I know some years were vacuum advance and some were vacuum retard, will this make a diffrence on whether or not the hose is supposed to be attached when timing?
Also is it possible for my dis to be off by one tooth? I am used to old Chryslers were of it is wrong it is 180 deg.
Sorry for the very related thread Hi-Jack
E
Poseidon,
The vacuum advance should not be functioning at idle. If it is, you have a problem in your carb.
A 71 should have vacuum advance.
You can be off 1 tooth. You can also be out 180.
Timing should be done with the vacuum advance line disconnected and plugged. Standard is 7 degrees Before top dead center (advanced), and is marked with the BB. Depending on your elevation, and sometimes with advanced age of the engine, you will find it runs better with MORE advance. This can be adjusted by connecting a vacuum gauge to the manifold and adjusting timing to obtain the maximum vacuum, then retarding back a couple of degrees. At an elevation of 5150, I find my 71 ends up at 14 degrees of advance (7 beyond the BB) using this method.
There's lots of numbers cast into my Toyota flywheel...516 13451 60010. visible just below where the timing marks are. There's also a "7" right next to my BB, and a "T" & a "C" by the TDC line
And, if Alstaz was standing near the rear of the engine (by #6 plug), shining the light down at an angle more toward the crankshaft, I could see how he would see those numbers.
Mystery solved?
So, Alstaz, while you can use #6 plugwire (it's 180 degrees from #1 on the dizzy) you really should fix plug #1 so it will trigger the timing light. Then shine the light through the window parallel to the engine and look perpindicular to the flywheel at the outermost, theoretically shiniest , area for the BB. It helps if the area is in shadow, or do it late in the day, so you can see the marks better. Also, it helps to take off the lower flywheel/clutch cover off and find the BB that way, and polish it up a bit.
Thanks, I think this will help me. I have a vacuum gauge and can check it that way. I am at about 4000ft. elevation. The thing just runs like crap with it set on the bb.
Hey Greg I like what you have done with your piggy. It was a cool pig at the 55 run but looks even better now with al lthe work you have put into it. I hope you are happy with it.
E
E
Hi E,
Thanks. Happy with most of it. It was a big step for me, didja see the bulding thread on POR?
'Bout time I post my Initial Driving Impression (on the 55 list).
(hijack mode off)
What kind of vacuum readings do you get on your Pig?
Mystery solved?
Thanks Pighead! This sounds completely feasible. I will bet that I was standing back looking at the angle you mentioned. I think I will pull the cover and polish up the BB. Thanks for the help. I guess I feel a little dumb now. :whoops:
Have you tried another timing light? I have seen ones that are bad and dont giving the flash anywhere near the right "time"
whatever you do in the privacy of your own home is fine...............but I don't need to hear about it :D
Man Pimp, I knew when I wrote that i'd leave the door open for someone. Oops there I go again.
