Weird electrical problem
It is a 94
While doing some night time wheeling tonight I had all my lights on (headlights, High beams, KC's, and interior dash illumination.) I stopped on the side of the road and turned it all off so the :princess: could use the bathroom in the dark woods.
When that was over, I turned the light switch on to the left of the steering column I had no illumination or outside marker lights right away, no popping or anything. I checked the Rheostat many times.
What works:
regular headlights
high beams
turn signal flashers
sunroof
clock
gauges (speedo, tach, fuel etc..)
A/C
What does not:
illumination backlights
KCs
The KC's are grounded to the body and get main power from ECU-B circuit. The switch I used is a toyota fog light switch and it was wired into the 2 wires from the Rheostat for the backlight. I pulled the dash apart when I got home and checked a few connections and ALL the fuses, they are fine. Any Ideas or similar experiances?
Not really sure, but I know when I had my illumination lights go out on my '92 it ended up being the dimmer wire in the stereo harness. No idea why it would spontaneously go bad, but it's a thought...
Figured it out!!
The Tail light relay is the first thing on the illumination circuit before it even gets to the rheostat. I pulled it out and it was toast, Black and melted even:eek:. It is located on the relay box behind the drivers side kickpanel and is Toyota Pn 90987-01003 and is the same relay used by the horn under the hood. I pulled the one from the horn to test and use for night driving while I wait for the new relay.
Im having gremlin issues of my own. Same issue as listed on this post. Relay is good, no burned fuses all light bulbs are good. Not sure what to do now. Wish i had known a few bucks ago about relay interchangability
Any assistance here would be very much appreciated. I do not have a FSM, Im getting one next week. This particular vehicle is a 94.
What works
Head lights
Turn signals
Flashers
What does not
Front rear marker lights
Dash lights
I have removed the trailer harness and anything else i have added to the system in regards to wiring.
I really want to avoid taking this in to the shop......
Friggin lights just went out, no warning no jiggling of wires will make it right. Its like someone flipped a switch
Thanks
Does your clock work?
If it does check your dimmer switch (move it back and forth and see if that does anything)
If it does not check your Tail lamp fuse 1 more time. There is a relay in the drivers kickpanel that controls automatic shutoff of illumination lights and tail lights after a certain period, it could be that or a bad rheostat (dimmer switch)
Thanks. I have already changed the fuse. The relay is new. The clock works. I have fiddled with the dimmer switch to no avail.
If you changed the tail light relay, I would check the relay that controls the automatic shutoff of the illumination lights and tail lights. It is above the fusebox in the drivers side kickpanel. I dont know the part # or price on that one but I would change that then get a new rheostat.
any other ideas here? This thing is going in the shop Friday. I replaced the combo switch same problem. Im defeated.....
