Weird brake light problem
My brake lights work fine until I turn the lights on-then the driver's side brakelight goes out. The tail light comes on fine, but when the brake pedal is depressed the light goes out. Info in the FAQ is inconclusive. Anyone have any thoughts? Its a 94' and I have cleaned the socket and replaced the working bulb with new.
Thanks,
Chris
Look at the brake light closely with the lights on and check if it is glowing dimly. If so this would indicate that the lamp housing ground is bad and isn't able to sink the current necessary to run both bulbs at full power.
I'm ignorant here-how would you suggest I give that a shot? I'm more mechanically inclined than electricak, obviously.
Thanks very much!
I just posted on another thread that I finally fixed my DS brake light problem (passenger side was fine).
It was very similar to yours. The bulb 1157 has 2 fillaments -- one for the tailights and the other for the brake lights.
If you turn your headlights on, the tailight fillament would go on. No problem. If you press on the brakes, the bulb would go completely out (both fillaments out).
If you leave the lights off and you press the brake pedal, then the tailight fillament would go on (but not the brake fillament) on the same bulb.
I couldn't fix it myself after checking the fuses, changing the 1157 bulbs, cleaning the contacts (dots inside socket) and wiggling the wires.
I took it to an auto electric shop here in LA and the guy fixed it in 5 minutes. He completely pulled out the ground wire (ripped it out) from under the socket (this was the white wire with a black line on my 1996).
He then spliced the wire and wrapped it over socket in between the black plastic and the metal casing. This is instead of inserting the wire back through the hole under the socket.
Brake lights are now working fine. Basically the ground wire was no longer making solid contact to the metal casing in the socket. So, the loose ground wire was causing the 1157 light bulb to malfunction in a weird way.
So, it cost me $15 for something that I couldn't figure out on my own.
The white wire with a black line is shown in the second picture in this post (wire under socket): https://forum.ih8mud.com/80-series-tech/297541-ds-brake-light-problem.html#post4653227
Thanks very much!
With the lens cover off, you would hold one end of the wire on the bulb socket and touch the other end to bare metal on the chassis or frame. If the light works, the bulb isn't getting grounded, either because of the problem posted above or the other end of the ground wire.
I have a soldering iron
I will take a look to see if this might be the issue
Well, I just try soldering the ground wire to the bulb housing. I didn't make it worse, but it still does not come on. The solder didn't want to stick real well so I put a bunch on just to see if I could make the light work and come back later to clean it up. No such luck.
Any other ideas? I was really hoping it would have been this easy.
FIXED!!! It was the ground issue. I opened up the tail light at lunch and my solder actually fell into the light so that didn't work. I took a 2" section of copper wire and spliced it onto the ground wire end and wrapped it completely around the bulb socket. WORKS!! I just need to go back in soon and clean it up.
Thanks, this board has been very helpful in just my first week of ownership, you guys are great!
Chris
