- Joined
- Jul 6, 2003
- Threads
- 43
- Messages
- 133
I'm experiencing some weird light bulb issues. A couple weeks ago I found that my brake lights weren't working. Seeing as they both stopped working at the same time (I assume) I figured it was a wiring problem. I had re-wired with a painless kit two summers ago so I figured it was surely something I did.
After hours of testing, chasing wires and making sure all the connections were good I found that the little nub inside the light socket (ccot rear light fictures '77) was recieving power when the brake was pressed, leaving the problem to be with the bulb. I thought it was strange that the problem would be with the bulb because both had gone around the same time.
So I took the other side apart and same deal, 12 volts to the nobby. So both bulbs are bad. I also put them to a 12volt testing battery and only the one filament, for the regular running lights, on each lit up.
The bulbs I had I believe came with the fictures from CCOT. They say "COSMIC 12V23/8W".
My question is, has anyone had problems like this? Are these bulbs just cheap pos's or something? The filaments look intact, unlike blown bulbs I've seen in the past which show an obvious break in the circuit. So the problem could be within the bulb, i.e. the grounding or something... i don't know.
I just thought this was very strange and thought maybe someone has dealt with this and may be able to shine some light...
I guess I'll just get some new bubls from NAPA tomorrow.
Mike
Mike
