Weird AC issue.
After suffering for a year I broke down and replaced the compressor, expansion valve and drier. Im a helluva wrench but ac stuff boggles my mind so I took it to a shop to have it filled. The shop said it held perfect vacuum and was at the right amount of freon. Fan clutch is a new aftermarket until I can rebuild the black hub I bought.
With a meat thermometer in the vent it gets to 58* at 90 ambient at idle. At 80 ambient it gets to 50*. From what I've read on here that at the high end of normal. .
But you don't get cold in the cab. Before I took it apart the fan blew unbelievably loud and hard. Now it's much more quiet and not as hard. It just feels like it has a lot more to give but for whatever reason it can't. Driving on the interstate doesn't change the amount of force thru the vents or the temperature.
This is a 95. My 93 and 94 were painfully cold. Even in Atlanta summers in traffic. So I know this can end better I just don't know how.
What says y'all? I can get any extra info you may need and I'm trying to find a set of gauges to borrow so I can figure out pressures.
Thanks in advance.
Will
Btw, the heater valve works properly
Is your evaporator coil clogged with debris? That would restrict air flow and cause ice-up problems, which restricts you air flow even more.
When you replaced the expansion valve I'm assuming you cleaned any built up gunk from the evaporator. Pressures are really helpful for diagnosing this kind of thing but until you find some gauges take a look at your condenser- if its full of bugs you'll probably want to clean it with some degreaser. The fan clutch can also be an issue, rebuild your black one and get it back in there.
Will
This is interesting, the vent temp (with AC on) should drop on the interstate- more airflow through the condenser and compressor is turning faster. I'm curious to see your pressures when you track down some gauges.
Yes the evaporator is free and clear. I spent a couple hours cleaning it up to be positive.
My blend door is working properly as well.
Hopefully I'll find some gauges by weeks end.
Do you hear a difference between outside and recirculated air? Recirc should be lots louder with the fan on hi.
Can you hear a change for all fan speeds? Your resistor might be bad if not.
Is the big tube coming out through the firewall getting frosty cold, or at least pretty damn cold?
Do you make a water puddle if you park it after running the AC? You should. Is the drain clear?
If you lightly spray water from a garden hose on the condenser, it should get quite a bit colder.
I recently rebuilt mine and I'm seeing 48F usually at the center vent. Sometimes colder, sometimes hotter if in traffic sitting.
