Weight of Factory Wheels...Alloy vs. Steel..
Here is the short steel valve stem I use. I'd really like one that is 1/4" shorter.
Short-Short Metal Tire Valve, Valve Stems, Tires & Supplies - GEMPLER'S
It comes with grommets for two common valve stem hole sizes. Above the nut you can see the extra grommet for the larger hole size used on many implement and tractor wheels.
