Weight bias
Ouch - you are about 3mpg worse than what I get for that extra 1000lbs, including towing (I've got 3500lbs rolling behind me). With gas projected to go upwards of $2 soon, this is getting painful, but FAR better than our friends in Europe. Regular is at $1.91 in SoCal.
Cdan, I have a slip that shows close to the same numbers. Then I moved your momma out of the way and reweighed it.
At last check, the truck weighed in at about 7,100 lbs with my fat arse in it.
[quote author=Junk link=board=2;threadid=11141;start=msg102633#msg102633 date=1076438708]
[/quote]
Looks like it's time to install a Cummins in that rig so you can still pull some hills. :o My 1 ton dually 4x4 with a CTD weighed 7200 lbs unloaded and a full tank of fuel. 7100 lbs is a lot to ask from a 4.5 liter gas engine, I'm guessing 8-9 mpg?
BTT
was looking for weight distrubution
97 FZJ80 said:
Stock weight distribution is 52/48
John
BrentBBA said:
Can't speak to the weight bias, but my stock, empty, '94 weighed in at 5300lbs
LET ME ASK THIS
so then for a stock unloaded FZJ does ~2750 on the front and ~2550 on the rear axles sound about right?
anyone have actual weights FR / RR ?
thanks
see also this https://forum.ih8mud.com/showthread.php?
if the truck is closer to 4900 lbs (maybe those are the 91 and 92's?) then at 52/48 it would be 2550 / 2350?
is the front rear bias much different on the FZ's vs. the FZJ's?
Go to your local truck stop and give them about 10 bucks and find out.
Wow, old thread! I drive across a scale once a week, most of the time I don't get the numbers, this week I did, 5320 lb without driver or spare tire, with a full tank of fuel, 280 lb of air tools that I was picking up for repair, about the only weight adding mod is the ARB bumper. Next time I will get axle weights.
