Weber flat off idle
Bonham Tx.
I searched thru 4 pages of mindless Weber posts with little or no tech......... :confused:
Got a Cruiser in on the trailer would not run, got it started and way high idle, found intake leak, replace gasket, woo hoo :D :D idles fine now, but flat off idle, acc pump is working but not being really used to these carbs it must not be enough.....it is a needle point spray every time the linkage is worked......... Is there anything else on the Weber that would cause this?
Customer had a kit, but no diagram like usually comes with a kit, is there a good online exploded view anyone know of?
Butch
from the little I know these carbs are real fussy about dirt in them. I've had the dead spot come and go. Usually I just take it apart carefully, so as not to ruin the gaskets, clean real well and put back together. Works everytime for me, but then again it does seem to return after I run it hard so aparently I've not controlled the dirt issue even though I have 2 filters in line. Sorry its not more technical, but maybe it'll help.
The idle jets are in holders on both sides at the top of the body. The air jets are in the center on the top, the e-tubes are directly beneath them in the body, and the main jets and power valve are in the bottom of the float chamber. The accelerator-pump jet is the little aluminum wing-shaped part overhanging both halves of the carburetor.
The carburetor will run on the idle circuit, but since this is the smallest jet, it is the most likely to become plugged. If you lose your idle, check this jet first as it's the most likely to be plugged and the easiest to get to. If you just can't get the engine to idle without propping open the throttle with the idle speed screw, the secondary idle needs adjustment (if your carburetor has in idle hole below the secondary throttle plate). The secondary idle circuit has no metering screw so you will need to clean or replace the jet if adjustment is needed.
treerootCO said:
The ...................................................................... has no metering screw so you will need to clean or replace the jet if adjustment is needed.
Idles great, down to 500 rpm, just bogs like a mofo like the acc pump is not working at all.
Timing dead on, it has a GM HEI I have not checked the vac advance but does not feel like that, much more severe......
Butch
Sounds like the transition or "off idle" fuel port or slot may be clogged. It is part of the idle circuit, so the clog could be anywhere from the idle jets themselves to the port outlet slot. It is located directly above the throttle plate when it is closed. You can try removing the idle mixture needle and spraying it with carb cleaner and then blowing it out.
If it is not clogged, it is also possible that someone changed to smaller main jets to correct a rich condition w/o increasing the size of the idle jet to fix the bogging down. Try larger idle jets.
Is this a 38/38 carb?
I have also seen where the accel. pump diaphram is pumping fuel, but is still bad. Mine ended up having a pin hole leak that was causing a very similar issue.
My issue was with a 32/36 dgv though.
