Weatherstrip Question/Concern
David70FJ40
Older Than Most
High Point, NC
When I rebuilt the 40 steel doors, I purchased the door weatherstrip from SOR, the kit for each door. The door weatherstrip looks like it is to thick, the doors take a lot of effort to close completely and the drivers door has the upper frame pushed out past the edge of the top. Is this normal? Do I need to look elsewhere for the door weatherstrip. I hope the photo helps to make sense of the question.
Same thing happened to mine when I redid all 4 doors with City Racer's. OEM weather stripping is a good bit squishier but I don't know if you'd still have this problem or not.
Here's my PS.
It happens with OE weatherstripping too. Unfortunately, with the pre-75 doors, the extra stress usually ends up cracking the lower shell where the upper channels pass through.
I only use OE at the shop, and give my customers a disclaimer about this problem.
Thanks everyone. More adjusting to do when the weather warms up.
