Waterproofing
San Juan Puerto Rico
Website
www.facebook.com
I have been searching for the last hour with no results. Anyone knows how the FJ80 ignition system can be made pretty much water tight? I have tried the WD40, plastic back RTV the wiring connections, etc. Any suggestions???:hhmm:
Does the 92 have the distributor breather? Not sure, but if so you could run an extender up higher like PHOTOMAN did. Other than that RTV around the cap and dielectric grease on the boots.
The distributor has an o-ring and a breather. Keep the o-ring lubed (I use Super Lube by Synco on all o-rings) or replace if visibly worn. Dialectric grease on all connections including the coil and you should be good. I think WD-40 evaporates pretty quickly and works better as a fix then as a prevention, but I am no expert.
Water 'Proofing' Ignition, Axles, Hubs, Ect. - JeepForum.com
I am going to do this to my 80 series. Since we have closed knuckles we can pressurize the hub and wheel bearings. Just thread a line into the inspection plug on the birfield bells.
Dammmmm, for that one I'll have to go to MIT!!! I was thinking to get an FJ60 rubber ignition cover.!:eek:
