Waterproofing the Distributor
Does any body have detailed pics on this mod? I am looking for pics showing how they ran the breather hoses from the distributor to either to the air filter canister, etc. I would like to do something similar.
Unless you hook it up to a vacuum and make 100% sure that the dist does not have a leak, I think the best route is to thread the holes, put a nipple on them and install hoses with shut off valves and use them as needed. OR, plug one of the holes and just run the hose from one hole to the other as needed.
I like the vacuum idea but not sure if the dist is 100% sealed if you seal the breathers.
I used a cork plug and it does keep the water out but breaks after a couple uses and then you need to remove the dist to get the cork out.
Is there much more than plugging the hole in the hole in the bottom of the distributor?
I have a new seal/gasket for the distributor.
I was thinking just plug you could stick in the hole to plug it when it comes bath time.
One thing that has worked for me is enclosing the wires and distributor in separate ziploc bags. Use tape to seal the bag openings as much as possible. Its might be a little more time but its better than dealing with a sputtering rig. What a PITA, ask me how I know. HA!
There is company called NanoProtech which makes very good product to help this matter, here is the link of the product:
Nanoprotech
Guys are also washing the distributor with water:
Here is another video with bigger detail (in Russian), guy is putting water into distributor:
I guess the question is do you need waterproof or water resistant?
My 3fe has a boot over the distributor which hasn't let me down during any water crossings. It's a little finicky to get installed, but seems to do a good job at keeping the bulk of the water away from the sparky bits.
Yes, mine dies and runs very rough when I give it a bath.
Mine throws a CEL if I get too much water on top of the cylinder head. Particularly #1 cylinder misfire.
Idles like old people screw for a a while.
CRAP...just realized I am replying to a decade old thread.
