Waterproofing the Distributor
test for the last two pictures
Hopefully the pictures will help tell the story on the install, by a couple quick notes I agree with evertybody above, first the 60 was superior with this vacuum system though with the 80 having the horizontal mount with this vacuum approach it will actually superior since condenstaion always seems to rise and form on top of the cap, infact after water crossing usually had problems the next day especially if I didnt go far because the moisture condensed in the cap. Photomans approach will work fine though with the dcap appproach you dont have to pull the dist, timing etc. Since I took the pictures last night I have went to a real hardware store not lowes or depot and purchased nylon 1/8" pipe by 3/16 hose fittings even though there is probabley no grounding potential plastic on plastic "cap to Nipple" has a much lower chance of stressing or cracking the cap and that how I did it on the jeep.
couple changes from my earlier post were pulling the Vacuum from the PCV system as I was installing I thought it was pretty stupid to pull from the FPR line in that it would kill the signal to the regulator since this will constantly pull a small amount of air through the cap.
Secondly as people have posted is to seal the dist vent so that you pull air only from the cabin space, will do tonight will use goop since to me its much tougher than silicone, and as you can see from the picture draw air fom the top dist "heat and moisture vapors will rise".
Parts list:
2) nylon 1/8"male to 3/16" barb hose
2) Vacuum check valves Help # 47149
2) universal Vacuum connectors Help # 47309
1) 5/16 brass barbed tee bought combo kit Help # 55109
1) 1/4" unversal inline fuel filter
2 feet of 5/16 fuel line
2 feet of 1/4 vacumm line or fuel ine
10 feet of 5/32 vacuum line
Tools
1/8" pipe tap
Couple notes on the install:
The help vacuum valves have one side that is loose and one tight to the 5/32 hose. lubricate the tight and it will go on and I wrapped a couple of rounds of electical tape on the loose barb to increase the dimension and you could put a mini wire tie also if it made you feel more comfortable.
Pay attention that the valves are in the right direction only pull air from the dist not let it back in.
Have yet to put the air line in the cabin but my pick is the driver side wire loom lots of room to push a 5/32 line through and then install the filter on the inside of the cabin probably drop it in the plactic piece that seperates sideboard from the feet.
I have read about some running the breather lines into the cabin. Seems extreme to me but then again what on here is not.
Dont have my fj60 any more but thats how they did it. It should have the cleanest and driest air "lowest humidity' in there. FYI on my Jeep commando I vented both front and rear differential housings and the transmission and transfer case, steering box, housing in a row with the dist cap, under the dash. have also dumped alot of watery oil out of weird places
WD40 will eventually melt and damage wire casings, use CRC. It's used on outboard engines all of the time.
For puddles in stuff, clean off the distributor and spray your wires and the cap with WD-40.
It's worked so far for me, but for deep water crossings, use other people's advice. Because I drive through puddles. :(
Sorry, forgot the quote.
