Water sound
Texas
I hear the sound of water (after the snow melted) underneath the dash and I only hear it when accelerating. Has anyone had this problem?
If I were a betting man I'd put my money on it being in your rocker panels.
Just below the rocker panels (which are below your doors as most know) are several black plugs ea one has a slit for drainage.
The slits sometimes get clogged and the rockers begin to store the drainage from the front sunroof drains. Use the male end of a zip tie to push into the slots and clear the drains.
Yep, x2 :cheers:
X3. Had that happen too.
I just leave one plug on each side open year round now.
I've checked and it doesn't get clogged like some expect to happen.
just my .02
Same thing I have done. We get enough rain here that leaving it open makes more sense.
Not to sound totally incapable, are they the black plugs that run along the side? There are about 3 or 4. Thanks.
That's the ones, just pop them out with a screwdriver, I bet you will get a decent amount of water to come out. I've found parking on a bit of an incline and pulling one from the downhill end will really help.
If that doesn't fix it and its only on acceleration, you might have air trapped in your heater core, accelerating flows water through a partially empty core making the running water noise. So if its not the rockers, bleed the cooling system.
I had this "sloshing water sound in the dash when you accelerate" issue, or as you describe, air trapped in the heater core... I read on another thread someone said to turn your heater on and go driving for a while and it will work it's way out. I don't understand it, but I tried it, drove around for about 20min and I'm not hearing the water sloshing around anymore when I accelerate. I'll see if it's *really* gone when I start it up cold tomorrow morning, or if the sloshing is back. ; )
A question I had to add is, what would cause that condition to show up to begin with? Do I have a leak in one of my radiator hoses or something? I'm guessing the answer is yes, as I do seem to remember a very slight antifreeze smell when I turned on the AC a few times.
Thanks for everyone's input!
There are a few factors that play into it, but it generally occurs when there is no coolant in the overflow container or after repairs to the cooling system have been made or when you have a failing hose like the PHH when the vehicle is running it pressurizes the cooling system, when it's hot it has more pressure, then when it is shut off and cools it creates a vacuum drawing air in around hoses or holes in hoses. You would likely be able to tell if you have a leak somewhere. If the problem persists you just need to Jack the front of the cruiser up and support it, the turn it on and remove the radiator cap. What I did for mine is bought a wide neck funnel from Walmart and cut the spout back until it was wide enough to just squeeze into the radiator fill opening and cover the overflow spout hole. If it's not quite big enough put a couple wraps of electric tape around the outside of the funnel neck and try again. Once there is a nice seal between the funnel and radiator fill the radiator and start the cruiser. Wait for it to warm up and add coolant to top it off. Then add an inch or two of coolant into the funnel so the radiator is over filled. Use the throttle cable to idle your cruiser up and watch for the radiator to burp air out of the funnel. As it burps air it will replace with coolant from the funnel. You may need to add a little more coolant until there is not more bubbles.. Idle the engine up for 30-60 seconds at a time. When you let it back down allow it to idle a bit. The coolant level may rise. All is said and done, ensure your overflow container has the proper fluid level and isn't leaking and shut the cruiser off, allow it to cool for a while and monitor the coolant...don't let it get down Into the radiator enough to leave an air gap. Slowly remove the funnel allowing the coolant to exit the hole for the overflow. When coolant level is below the overflow hole replace the cap. This should alleviate your problem.
That is incredibly helpful info - I appreciate the extra details, which removes any faulty assumptions that would've been on my part. I'll give this a whirl this weekend. Thanks very much!
I attached a picture of the Walmart funnel I use, you can see a rib on the spout. I cut mine just at the bottom of that rib and it works for my land cruiser, my Camry and my girlfriends 85 Toyota pickup. Tape may be needed for some applications as mentioned.
