Water pump studs for 3fe ?
Plano texas
Hi, Who has a source for M10x1.25X 60.325 studs for the water pump ? I need a few studs to remount the water pump . The sources I talked to don't go that big . Thanks, Mike
Just drill down into the fastener section on the site and find studs. See if there's something suitable.
M10 x 1.25 is always difficult to find.
That's the problem I've looked and called suppliers all over the country for 2 days. Georg and Beno didn't know and they are good. Mike
What I said is that they are discontinued from Toyota.
What is the length of the center shank portion? What are the lengths of the threaded portions on each side?
McMaster has a stud with the right dimensons exactly but they are their "low-strength" version. Probably fine, the water pump is aluminum.
Sounds like you know what you need to look for.
Bringing this thread back from the dead...was wondering if anyone could help me out. I would like to replace the studs for the water pump block housing on my 2h engine (i know its not a 3fe). I have found some grade 8.8 studs which seem similar to the originals. However they are painted black...don't want any troubles with rust! Last image with originals. Any ideas if these would be OK? Thank you
