Okay, I'm starting my powersteering conversion of a 1978 FJ45 and I have all of the parts that I think I will need. Anyway, I started yesterday by removing the water pump pulley and then the 1 13/16" nut on the crank shaft pulley.
The first problem I ran into is I'll need a pulley puller for the crank shaft pulley because even though the nut came off with ease, the pulley isn't moving.
- Is there a particular crank shaft pulley I'll need or can I just rent any kind from Autozone to get the job done??
Next, I went to test fit the 2-groove water pump pulley that I picked up and to my surprise, the pulley doesn't fit nor does the pulley grooves line up properly. It appears that the four holes for the bolts are further out from center than the single groove pulley I removed. Well, I'd really prefer not to have to replace the water pump if I can get a two-groove pulley that would fit what I currently have instead.
- Do I have a FJ60 2-groove pulley or a 1979 - 1984 FJ40 pulley, or should I be asking myself whether I have a 1975/76 water pump on my 78 FJ45???
Anyway, I know that it is kinda hard to get feedback if I don't have pictures, so I'll take some tonight and post the two pulleys and the water pump that I have to help solve this.
Thank you in advance.
