Water Pump/fan Upgrade
Discussion in '40- & 55-Series Tech' started by shad40, Feb 27, 2007.
  1. shad40
    shad40
    18
    Jul 24, 2004
    I Am Replacing My Radiator/water Pump On My 11/75 Fj40 And I See Coot Has A Combo Water Pump/pulley/fan Clutch For The 8/76 And Newer. Besides Having To Purchase The Newer Fan Blade Would I Be Able To Fit This On My Unit?[bolt Pattern Etc] I Would Like To Employ This Upgrade Because My Cruiser Runs Cold All Yhe Time Especially In The Winter With The Fan Running Constantly. Any Input Would Be Appreciated.
  2. Coolerman
    Coolerman SILVER Star
    6,124
    Media:
    2
    Albums:
    1
    1,050
    Jan 5, 2004
    Paint Lick, KY
    Go to the FAQ section and/or do a search on 'won't warm up' or upper thermostat gasket either should return some hits on possible causes for this and it's not the water pump or fan...
  3. Degnol
    Degnol
    8,121
    Media:
    16
    Albums:
    1
    19
    Jan 22, 2003
    Kansastitty
    The clutch fan is about 1" larger in diameter than the direct drive 6 blade. You will need a new shroud. Is the clutch Toyota or aftermarket? I think you might be better off posting in wanted for a clutch and fan as wellas the shroud and just buying the waterpump.
    Ed
