Water pump again
I am getting ready to replace the water pump....no fan clutch, no oil cooler, 6 blade fan...anyway, the front bib hinge....can I just take off the 2 bolts (with the long bars that hold the radiator to the frame) off and lay down that clip to access the fan/pump? What other bolts need to come off and is that what the bib hinge is for? The pump is leaking out of the weap hole on the bottom.
Chris
Chris
I'm assuming F/2F?
I've done mine several times and never bothered to fold the bib down. For my 64 (early F), I just pulled the belt & hoses off the pump, pulled the 6 bolts for the shroud, then slid the shroud back over the pump. Then the fan bolts are easy to get to and everything else is cake from there.
I've done the water pump on my 2F a couple times, and I'll echo what they've said. No need to mess with the bib. Hoses and belts off first. Then fan shroud bolts off, pulley bolts off, remove shroud and pulley together. Then you've got a clear shot at the pump.
It's pretty simple, unlike the same job on a 3FE. Just did that this weekend; it sucks.
Got those, now does the whole clip just rotate forward?
Once loose, it rotates forward about 45* and comes off....provided you have no hooks, no winch and your bumper will allow it.
It can be done like eRock (and Felix)says. The fan shroud can be a bitch to get back on, so don't snug anything till they are all at least started.
Ed
