water leaking into interior
Boone, nc
I searched the subject a while ago and found that it could be my sunroof drain, i cleaned that with a pipe cleaner. Yesterday we had another good rain and it was leaking again. Just a little drip drip i notice it most when i am pointed downhill. It drips just above the grab handle on the drivers side.
What is it?
Is there a way to clean out my s/r drain better?
thanks.
I just found out a few days ago that mine has a leak from the sunroof too. I used an air compressor to clean the drains out. You might want to try that if you didn't do that; it may dislodge some gunk the pipe cleaner didn't. Haven't had much rain since I cleaned it so not sure if it resolved my leaking issue.
Keep us posted if you find another way to clean the drains out better.
Salue
Boone-- theres lots o info on this one, although i havent witnessed the drip by the grab handle. My guess would be still on the sunroof drain. You need to clear the drain all the way down the a pillar, not just the visible hole. I used a 6' section of string trimmer string, yes 6 FOOT. My cruiser resides under a huge oak tree and the catkins stop up the drains pretty fast, especially now in pollen season. at least its easier to fix than a leaky windshield:bang:
I had the same issue after the same rain storm Boone. I ran some weedeater line down it, and then went to some 1/4" or 3/8" clear tubing. I ran that in as far as it would go, then blew into it with mild pressure. No air compressor..
I had my rear trim panel off on the passenger side, and pulled the black hose that runs down thru the quarter panel out. I wrapped my hand around the shop vac tube and sucked thru that drain line. That cleared the back one out. I then blew air thru it (low pressure mouth exhaling) until it was clear. I still need to do that on the drivers side tube. I "think" that may have solved my problem.
I ran mine with both heaters on max to try to dry the carpet. I pulled all the trim out on the passenger side (the wet side for me) and lifted the front carpet up so the hot air from the center vent would get under it.
Thanks i'll give the shot of air a try and then the weed eater line. I'll post up with my outcome.
The dealer has a special tool for this. It resembles a smaller version of a handheld pipe drain cleaner...you know, the ones with a spool of cable that comes out as you crank it. The cable is about 1/8 of an inch IRCC.
