water leak.....help!!!!!!!!!!!!!!
CANADA
gotta water leak, water on the front ps floor, had the sunroof drain serviced 2 months ago, what else could it be, thinking to replace windshield as u can push on it and move it a little but has never leaked before, i got my front speakers replaced...could it be the plastice water guard if there is such a thing...my 98 dakota had them...please help as my truck has an inch of water every morning and i'm sicka shop vac'ing it
anybody?.........
Well, I just fixed the same area leak on my rig with cleaning out the front sunroof drains with wire so...don't know what else to tell ya. I opened the sunroof, poored water down the front drain tubes and saw it was coming out from the PS pillar near the grab handle and down under the dash just in front of the door. This proved to me it wasn't the windshield as I first suspected. Good luck!
anybody?.........
i had more time today and tested the windshield, its ok, but still shotty gasket job...but not it, i tested the sun roof drain and yes it did come down in the exact same spot as u except by the grab handles...but that happens when i drive through the carwash, what u do to fix it. i attached an air line to the drain hole etc and full pressure comes out the bottom end of the hose. whats going on then??????
help, raining lots!!!!!!!!!!!!!!
Crap. Maybe you have a kinked drain line, or?? I don't have any other ideas for you except to check out JerseyCruiser's thread, Sunroof Drain Fix in this section for possibly more help. :confused:
Good luck!
