water issues
It is most likely caused by sun roof drains clogged. Use search to find numerous ways to fix it :hillbilly:.
the sun roof drains are good and clear, I checked and rechecked, other than the sun roof drains, any other posibilites?
could water come in through the door seals, its pissing rain outside?
I just replaced a leaky windshield. It was pretty bad. Tiny streams of water were leaking in from both lower corners which soaked the front mats and carpet. I though $200 installed was cheap. Haven't had the car out in the rain yet; confidence is high though. :clap: Now it's off to trans fluid, fuel filter and front axle job. :wrench:
jt
jt
Did $200 include the glass or just a re-setting of the glass?
That was with glass and installation. I thought it was cheap too. The guy did a nice job and so I gave him 20 bucks extra. His helper was another story though. I would not have let him do anything on my truck.
I spent another ~$30 for a new windshield gasket from cdan.
It turned out nice. Even the wife noticed how clear the new glass looked. :rolleyes:
Then I was able to mount a new autodim mirror with temp, compass and maplights too. Those require a windshield button or mounting base.
jt
my windshield is fine, but it leaks. i don't think it's the original glass, but it looks fine. it leaks in both of the bottom corners. i just want to have it reset. 1996LandCruiser, where are you located so I can compare prices from my area as I imagine prices vary greatly.
What is the part # for the gasket needed to reset the windshield?
I'm in NW Indiana, about 50 miles from Chicago. I had 3 rock chips in my original windshield so with the gasket leak it was a good opportunity to replace both.
Not sure about the gasket part #. I would just call cdan. He is da man.
jt
