Warn winch in ARB bar
Canberra, Australia
I've just picked up a Warn M8000 winch and have an ARB non winch bar.
I'm after advice from those that have installed similar. How did
you mount it on the bar? Did you add some extra
bracing/brackets/supports? How did you cut the holes? Are there any
write ups on how it was done?
Whilst in the topic does anyone have an overhaul guide in electronic
format they could send me or post here?
Thanks
Winch install in a non-winch ARB Bull Bar? I believe I have found information by searching on this topic. From what I recall, this can be done but would require additional welding to reinforce the bar in addition to cutting an applicable hole for the fairlead.
You might be better off trying to swap with someone who is interested in a non-winch version or sell it outright and buy a new winch bar for $700-800.
Others may offer different options....my 2 cents.
Dave
What's funny? I hear they recommend 1.5 times minimum. Most folks recommend double or the 12k version.
Is it that 8k is too light and if really stuck in the muck that it could over strain the winch?
Dave
Dave
Exactly. But more than that, an 8K winch comes with 8K rated cable and 8K rated hardware.
Recovery gear should be purchased for the worst case scenario, not what's affordable. If ANY part fails it might cost a whole lot more than money. When you have put your life and your child's life in danger and are literally "hanging by a thread" you will understand that vehicle recovery is not something to take lightly. There is no such thing as strong enough.
I agree Jon and if I could affort better I would have purchased better. There are many ways of mitigating the lower capacity/rating of the winch and whenever I use it I will be very mindful of the winches rated capacity and for the most part will be doing double line pulls. Mind you I've been 4WDing now for 6 yrs and this is my first winch so I don't forsee a lot (if any) use for this one. When I trip over a bucket full of money I'll purchaes a better winch, 'till then this one will have to do.
Thanks for the info Bat.
Your winch should be fine. Just make sure you use grade 8 hardware and mount it good.
The 1976 FJ 40 I have came with a warn 6000. It was the early version of the 8274 right after they bought the design from Bellview.
I have never had my FJ 40 or either of my FJ 60's stuck to the point it would not pull it out with a single pull.
I've had to double the cable once when I pulled my Kubota B2710 4x4 tractor out. Mud was over the floor boards.
I would agree with Bat. If possible I would try to sell that bar and move to an already winch ready ARB. The additional welding and shoring up will prove difficult and not worth the time or $$$ IMHO.
Also if rigged properly an 8K should be fine for most applications. Sounds to me like you know what you have and how to use it so I wouldn't fret about the weight part of the equation. As long as one is responsible and thinks there way through things all should be good.
