Warn m8000
Hi All:
For "low-mount" winches like a Warn M8000 the basic "boiler plate" winch mount is sufficient. The "boiler plate" is simply a very thick piece of mild steel that bolts to the front frame rails of the 40/45/55 Series TLC.
Go to <http://www.man-a-fre.com/parts_accessories/alphabet/w_parts.htm> and select "Winch Mount Warn MX Series FJ40 & 55" for an example of a fancy version of the 'ole boiler plate winch mount.
Regards,
Alan
this is mine, its a MX8000 mounted in one of CCOT's winch mounting channels. the channel bolts to the frame were the old tow hooks used to be.
Here's my setup. Custom bumper, custom mounting brackets that position and support the roller fairlead. You can see I also moved the solenoid assembly as to clean up the look and move it outta the way of air to the radiator. I had to make new cables.
I'm considering an M8000 myself. Maybe you already have purchased yours but if not you might want to check out 4 Wheel Parts Wholesalers. They're running a deal that I think lasts thru 8/31, M8000 with roller fairlead for $550 and a free tow strap or tow hook, maybe even free shipping. The other place I've found with good winch prices is Clemson Off-Road. They also have free shipping on winches, not an insignificant amount.
For a mounting plate, I plan to make my own from a piece of channel. Look at CCOT's winch mount plate for dimensions. I'm sure I can get a piece of structural channel close to those dimensions, drill my own holes, and fab a fairlead mount if necessary for less than the $75 or more (plus shipping) everyone seems to get for a mounting plate.
Pete
On my last 40 I welded a plate between the bottom of the frame rails and mounted my 8000 to it. Cut a hole in the bumper and ran the cable out through the center of the bumper. Had to sligtly trim the upper bumper mounts to allow the winch to fit. I felt it gave it a very clean look as the winch sat very low, and did not block any of the radiator. Will see if I can dig up a picture of the old girl.
Not sure if you would be able to do this with a power steering conversion or not.
I bought it at the same price at winchdepot.com; 549.99, free shiping.
Just a question dgangle; why did you put a chevrolet emblem on the grill of a FJ40!!
what should be the correct thickness of the plate to bolt on the frame and the winch? planning to do one similar to CCOT's one, thanks!
