Warn M12000 replacement solenoids
miami, fl
hello to all,
has anyone replaced their solenoids with an Albright in a M12000 winch? Which part # did you use and where did you purchase from?
I had seen some posts earlier when I was researching but can't find them now.
thanks for the help
Just searched the same last week and found several threads.
Try m12000 + albright
There is a popular superwinch solenoid. Albright style
Or a Warn albright replacement that has a safety backup feature for ~$100 more
some more info here about differences
Cut n paste:
The main differnce in these two contacors is the unit WARN uses (34971) is what we call a triple contactor or protected contactor. What this means is there are three coils, the current always goes thru the #1 coil, then to the power-in or power-out coil. With the protected contacor, if one coil welds itself together, the 2nd will still disconnect and the winch will stop operating. We use these in our Industrial Winches where they are sold into applications where they traditionally get used daily. This contactor is rated 100amps continuous duty.
Buried in here
Superwinch 90-14452 solenoid vs Warn 34971 contactor?
Which also has this tidbit from woytovich
"and they specify part number 83668 as the replacement for the M12k winch."
Wiring for remote may be different.
thanks everyone
