yall should just sell those and get a t-max. hehehe
The M12000 is designed for feet forward only, so I wouldn't expect you to have a problem if that is how you mounted it. If you are worried, pull the motor and have a look for signs of water damage and to check the drains.
gr
this is another great example of why i do not understand everyone's die-hard loyalty to Warn. Every time a winch thread gets going everyone says spend the extra money and buy a warn since it is bullet proof and will never fail. I bought a t-max 12,500 and saved over $500, have used it numerous times and still have no water issues.
I just don't understand....
The part that snapped is a small planetary gear unit on the motor side, it's called the "Stage 1 carrier assembly". But Warn doesn't sell just that piece, you have to buy the entire drum support, another $225. WTF???
I guess I'll call Warn on Monday, but I'm pretty sure they're gonna tell me I'm SOL.
The tech Eric was really friendly, explained that it's not a bad idea to at least pop the gearbox section off occasionally and check the grease. He also said it's not good for them to sit unused. Even if you just unspool and respool it occasionally, it helps. I guess that makes sense.
