Wanted: body mounts 1985 FJ60 complete set
Ok, laugh if you must, but two or three boat trailer rollers cut to desired length with a bandsaw will do the trick for about $30-$40. Just find them online and try to match up the hole size. These are usually rubber, but poly may be out there too. Just saying...
Not laughable at all! That's what was recommended before Roger brown was discovered. Works very well.
In fact I just used a boat roller to make a front bumpstop for a friend's SAS uzj100 a week ago. Works mint in that application too.
Did you also use the bolts in the kit? I am needing bolts (doing a body swap) possibly if the stock bolts happen to break in the process...
thanks!
I too confirm that these 4Crawler body mount kits are legit. Came with the correct hardware also.
