I tried to install the bezel of the LC in my LX directly, but it didn't work. Even when wire harnesses and plugs are match. I faced what you faced “The buttons that controlled the air flow weren't working in the LX.” But with LC bezel.I had to swap the bezel from my 98 LC -> 00 LX and vice versa. The buttons that controlled the air flow weren't working in the LX.
After swapping, the LC (with LX bezel) works perfectly, as does the LX (with LC bezel). It's a very straightforward process just pop out the bezel w/ trim tool and unplug the wiring harnesses. All the wiring harnesses match up nicely between both.
Photo below is the LC w/ LX Bezel
Hey Cbranch, you put an LC center bezel in your LX, too? Can you send a picture? I need to replace my trim around my radio and climate controls and am looking to see if there is a way to put a LC climate control into the 1998 LX, too. ThanksI had to swap the bezel from my 98 LC -> 00 LX and vice versa. The buttons that controlled the air flow weren't working in the LX.
