Reading through some of the threads has motivated me to pull it appart and see how its fairing. Its been on the 75 for about 19 years, has done a little work but not alot, has been drowned plenty of times and I had always wondered how much that would affect it.
So I have pulled it off and started to strip it down. The winch appears to be working fine but has not been tryed under load for a few years now. Most of the bolts holding both the bar and winch were starting to corrode a bit so they will all get a good clean up and a smear of boating grease before going back in.
The motor side is pretty clean and appears that it is seal reasonably well. I am sure someone will correct me if I am wrong about that.
The drum is a little rust but nothing a good clean would not fix. I have always been pretty pedantic with the cable so it seems pretty good. No needling, no kinking only the odd defect but nothing to be concerned about other than the eye which I will get reswaged. THe eye has no thimble and has flattened at the hook pin.
The gearbox side? Well? It needs a little work. It has obviously been full of water and mud and that appears to be mixed with a bit of grease that has probably limited the amount of corrossion. I have uploaded a couple of pics so hopefuly it works.
Havenot stipped it down any further yet but when I do I will try and post some more pics.
In the mean time I have a couple of questions.
Do ppl use grease on the drum bushes and if so what sort?
How mush endplay should be between the drum and the casing? Should the nylon/plastic washes be loose, snug or tight?
What sort of grease in the gear box is recommended?
any tips befor I start pulling it down?
