waking an engine from hibernation?
Hey guys. I just got back from Iraq and am anxiously awaiting my first spin in my cruiser. Only problem is that the guy that was supposed to start it every month and run it around every once in a while...didn't. So now my cruiser has been sitting for the better part of a year and I am afraid to just throw a charger on the battery (it's dead) and start 'er up. Any suggestions on what to do in this situation or precautions I should take. Any help would be great, thanks.
You should pull the dizzy out and turn the oil pump to pre oil the engine. I use an old dizzy shaft that I put in a drill but you cut the handle off a cheap screw driver or grind down some round stock.
Other than that, I'd put some fuel conditioner in with fresh gas to top it up if you haven't already and maybe the carb will need some cleaning too, but I'd try to run it first.
Edit: I'd do an oil change too, may have accumulated some moisture.
Sitting for a year is no big deal for the engine. You might want to change oil and crank it over with the coil wire out to build oil pressure, but I would just charge it and start it up. You might encounter some problems from it sitting so long. Carbs don't like having the fuel evaporate from the bowl.
Once you get it running. Please take a moment or two to show your thanks to the person who failed to take care of you while you took care of all of us.
A year is not a big deal. especially a complete engine with an aircleaner assembly and exhaust system in place. I've had engines sitting on pallets for lots longer than that with no ill effects. Toss a battery in there and start it up. Make sure your accel pump works right. About the only thing I would have any concern about would be that if the fuel has evaporated out of the carb, the check ball in the bottomof the accel pump bore *may* have oxidized in place. If the pump works then this is not a problem
Drive that sucker.
Mark...
