After reading P0401 threads until my eyes hurt, I figured it was time to solve my problem. I did the usual tests per the FSM and narrowed it down to the VSV.
I figured I was going to have to pull it to really test it so I called CDAN at American Toyota and ordered the part along with the EGR modulator and several feet of the small vacume hose so I could replace it while I was in their.
Several posts describe using three feet of ratchet extensions and removing the intake support bar to access. I tried a different approach.
I pulled the throttle body (TB) because I wanted to clean it anyway. The gasket was reasonable (from CDAN of course).
Removing the throttle body was strait forward and access to the VSV was real good once the TB was removed. I did not have to lay on my back, nor remove the manifold brace. I suspect it takes about the same amount of time to access the VSV this way. The bonus is you have access to really clean the TB behind the butterfly and all the little passages that supply vacume to the modulator. (the FSM describes draining the coolant to pull the TB. I found this is not really necessary as less than a cup drained out of the hoses/TB)
I bench tested the old VSV and it was out of spec on continuity between the two posts. P0401 appears to have been defeat and no more annoying MIL.
Hope this is of some use to someone trying to replace their VSV for EGR.
For those that count bananas, I woudl give this approach about 1.5
's
's
