VSC Off and does not want to turn back on
Phoenix, AZ
I’m getting two indicators on the dash.... “VSC Off” is flashing and the Active TRAC indicator (vehicle with squiggly lines) is flashing when I start the vehicle. Pushing the two associated buttons does not seem to be resolving the issue, including the 3 second push that should turn it off in the first place. I’m not getting any other indicators and I’m not getting a Check VSC System indication. Some more background...
I had the truck in the shop to get some minor bodywork done and the installation of new Slee sliders. The indicators started the first time I turned the truck on since getting it back.
Any thoughts? Could the installers have goofed up something under the truck when installing the sliders? Could they have tilted the truck or done something to throw off the VSC / Active TRAC systems? Appreciate any help or suggestions. TIA.
My guess is your center diff is locked. Hit the button and drive around on a loose surface in some figure 8s if it doesn't unlock easily.
Bring it back to the shop that did the work.
It’s actually back with them right now for a couple of other things. I will suggest they do what mcgaskins recommended.....but other than that I’m not sure I want them goofing around with anything important on that truck.
Abs speed sensors wire? Is there a code being thrown as well?
