I am in the middle of a wiring job and dont know where the voltage regulator is located? Is it the box on the drivers side firewall? Its a 10/74 fj40.
Thank you in advance
CruisinGA said:Yes it is the small black or blue box on the drivers side of the firewall. Three wire plug.
Toyota internally regulated alternator maybe. GM- NO THANKS!
Changed a few too many of those to actually desire one.
Install and run it.Poser said:So when you get a winch and dual batts and blah blah blah, what are going to go with, one of those late modle, ' high output ' 55A units?
. Basically, you need a wiring schematic other than the Painless, such as a Haynes. If you are hooking up the wires from the regulator to the alternator, you will need to save your plugs... unless they are ruined. Mine were old and cracked, so I got Deutsch connectors - expensive, but they are military grade and will last forever. I hope to high heaven you have a wiring schematic. Basically, with a Painless you have to combine stock Toyota Wiring with the Painless routing system. The main thing to remember about Toyota FJ40's is that the wiring loops are usually a *grounding* circuit, in that the power goes to the xxx first, and then the switch just completes the circuit by grounding it. On the 3 piece plug for the alternator, the top goes to the top of the plug on the regulator, the side to the corresponding side (if you were to face them in the same direction next to each other, the inside slot on one corresponds to the inside connector slot on the other and the outside to the outside... I hope that's clear.) I wish you the best of luck, and since I just got done doing a rewiring job on my October 1974 FJ40 this past summer, personal message me, AIM me, or something and I would be *more* than happy to help, as I remember how much of a chore it was. I wish you skill, not luck, because skill lasts longer!
