Vortec Replacement...Let the Fun Begin
isotel said:
id move the engine backward and keep the stock Belt setup.. That could be a real Pain in the ARSE to track down all the stuff needed.. then you need an old school short water pump..
shorten/lenghten Driveshafts is a pain, but not worth all the other hassles IMO..
RustyNailJustin said:
There is no way I would ditch serp for V belt thats a bad idea IMO. Move the engine back if you gotta. Its not hard just a bit time consuming..
Agreed...
it will be less of a hassle to properly place the motor/tranny than it will be to deal with all the other issues associated with the way the motor is improperly positioned now. Thats my opinion.
Im going to try to keep my serp belt set up. Im still not running the compressor or the PS.. no need right now. I have thought about a york along time ago but never followed through with all the research I did... then I decided to do the swap..What the hell was it thinking;) .
I was trying to minimize costs.... but thats out the :flipoff2: window right now.. I'm taking the time this weekend and seeing if the fan will fit with the mods i was thinking about doing BEFORE i do them and THEN realize....that it doesn't...
Thanks for the inputs...keep them coming..
BTW for the VORTEC guys... how far IS center motor mount to rear shock mount??
Cheers
Cooling Update
Finally got off my :censor: and started figuring things out.
I decided NOT to move the motor back 3" (for now). I decided to move my rad ofrward as far as possible and trim my Traurus fan. I also grinded down where my old clutch fan attached. I went to my local parts place and spent an hours trying to find hoses that will come clost to fitting.
Here are some pictures and wiring I'm thinking of running for the fan.
After I trimmed the fan some, I lines the plastic with some soft vacuum line split to ride on the edge to prevent chaffing. I wanted to make sure this thing didn't move at all so besides using those thru-raditor mounting tabs, I fabricated some other metal brackets bolted through the plastic and also to the radiator. I did 2 on each side. The thing doesn't budge.
Finished product.. I admit it's a tight fit.:D You can see where I grounded down the old clutch fan mounting.
Here's the Diode pic. It prevents the fan after turn off and free spinning to act as a generator prolonging life to your relays. The current onlt goes one way... to ground as opposed to backing up you + to the relay. One word of caution...I decided to get creative and solder it to the low and the hi side on the pickups... I wouldn't do it this way the next time I would do it in the wiring harness!! Makes it much easier to the the assemble back together:doh:
Diode is to the top.... Got it at radio shack part # IN5404 3A 400PIV
Cheers..
