I finally hoisted my motor (4.8L Vortec) into the engine bay today and I've got some questions before I go and weld the mounts in. I'm hoping to use the stock exhaust manifolds. The passenger side exhaust manifold exits in a pretty good spot... but the driver side looks kinda lousy, especially since the slave cylinder and clutch fork are in the same area. It is angled towards the frame and is closer to the frame than the passenger side. Routing the exhaust off the driver's side manifold looks like it'll be a real challenge.
Those of you running 4.8L or 5.3L Vortecs... are you using stock manifolds? How did you deal with the drivers side exhaust? Got any photos?
Also... the passenger side manifold is 2.5" diameter while the drivers side manifold measures a little less than 2.25"... why on earth?
Here's a shot of the drivetrain. 4.8L Vortec/SM420/dual Marlin mini truck Xfer cases.
Scott Wilson - 1966 FJ40
Morgan Hill, CA
Morgan Hill, CA
