Finally! I got the dual battery wired up and its working great. Only thing is my voltmeter that was always pegged at 14 before now has a ton of flucuants to it. It will drop clear down to <10 with the lights on. When I tested the batteries they all were fine. >12v at rest on each. Alt is putting our 15.6V and I lose 0.7v through the isolator. So my net voltage at the + cable is 14.5-14.9.
The only change I made in the system was to the alternator (3-wire delco). I took the sensing wire off the rear post (which would have read voltage to the isolator-in post. I relocated it to the + post on my main batter. Now its sensing actual voltage at the batter--taking so the drop across the isolator doesn't cause poor charging.
Could this be the cause of my voltmeter dancing all over the place? Where does a voltmeter normally get it read from (fuse box/battery)???? The third wire off the alt is the "warining light" wire that I think is inactive as its got a fusible link with an in line fuse but no fuse present (shouldn't work right??)?
Anyway, its just a curious thing cuase it all worked fine before. Let me know what you think might be going on. Thanks
