Well with help from here I seem to have fixed my starting issue on my 95. Replaced the battery (tested bad), starter, and bad connector. However, during my searches regarding this starting issue, I ran into a few comments regarding the light above the voltmeter. Most were observing that the light was red instead of amber when they experienced starting issues.
In Romer's emergency procedures manual in the FAQ regarding the fusible links it states " ....if you get the yellow light on the volt meter with “key on engine off” this fusible link is good."
Since I have owned the cruiser I don't think I have ever seen that light be amber during start up. Even now, with my repairs done, it is still red. It is not on when the truck is running. According to the scangauge I am generally reading mid 14 volts while driving but have seen it dip to 13.9 volts. However, everything in the truck works fine. Could you have a bad fusible link and still have everything work? I didn't think so.
Any other reasons the light would be red with out affecting drivablility?
Ross
Ross
