Good Morning,
My latest task is that my ampmeter is very erratic. So with the cruiser running I check the voltage and get 12.7 volts. I know that is too low so I am thinking that this is an excellent oppurtunity to upgrade the ext voltage regulator. I follow the solid state recommendation in the tech links and buy a VR128 from NAPA. This is where some confusion starts. There are three post on the regulator: This is how I connceted them.
BAT - Black Yellow - I think this is the battery 12 volts
ARM - Red White / White Black (there is a switch in colors at connector) - I think this is ground
FIELD - Green White - I think this is coming right off of the alternator
Connceted everything and cruiser started! The ampmeter is real steady (hmm?) so I take a voltage reading at the battery and it is still 12.7 volts. So I guess the question is. Did I hook the regulator up correctly? Does this mean that the alternator is bad instead of the voltage regulator?
Thanks for the help in advance
Travis
Travis
