Viscour Coupler or Locker stuck??
Florida
I know this has been covered here, but I can't makes sense of what I'm experiencing relative to what I read when I searched. Based on what I read I think my viscous coupler is starting to bind, in the early stages of going out, but I am not certain, and would like advice on what specific test to perform in order to determine what problem is.
What's going on is this: With one front tire in the air I can't rotate the tire. The truck has lockers and cdl switch, but al that is turned off, and works properly. Well, as of just the other day when I lock everything, the lights on the dash come on and both axles locked, and then everything unlocked. I know this because when I drive, the axles don't bind in tight turns in parking lots, so there is still some slip in the VC, but not enough that I can turn a wheel with one wheel in the air.
So what do you think? Is my VC starting to bind?
Chock the rear tires, get the front tires off the ground (on jackstands so we don't read about your accident in the paper ;) ), put the transfer case in neutral and see if you can rotate the front driveshaft by hand. If you can't or it requires you to use leverage to turn it the coupler is probably on the way out.
OK, I raised the front end and put the T-case in nuetral and the front drive shaft is very difficult to turn. So I guess my VC is starting to go. As much as I've always wanted to put a spool in and covert to part time 4x4, I think I'm gonna s*** can this truck. It is from Ohio so it's rusty, the PS box is leaking, the knuckels need seals, and the engine burns a quart of oil a month. Maybe it's still worth somthing since it has lockers.
Question, will these axles fit on a Tacoma?
Anything can fit most anything if you have mad fab skills.
The 80 axles are wider and are designed to run coil springs. It would be one helluva lot of work.
You don't need the coupler. You can remove it and toss it in the bushes off to the side of the carport and run without it. My wife's truck does not have one in it at the moment.
Yeah, I read on here that the VC coul be deleated without crippling the truck. I reckon I'll wait till it locks up to worry with it. Thanks for the input.
