Parting Out Virginia/DC part out 1988 fj62
Hi JK...do you have the bracket that holds the two 4WD solenoids (vacuum valves)? This bracket is located at the rear right-center of the engine compartment near the top (circled in white in the photo below). I also need the connectors off the wiring harness, that connects to the solenoids, so if that harness is damaged can you include those too?
I have the bracket but not pulling it from the Solonoids. Also not cutting the connectors off the harness.
No, I wouldn't expect you to cut up the Cowl harness unless it was already butchered. How much for the bracket and solenoids (and do you know if they work?). Rusted or in good condition? Thanks
Do you have one of these for an late 60? Curious what they cost....
Hi, would you happen to have the AC cooler housing, the AC lines that run from the cooler through the firewall, and any of the other pieces below? Thank you.
do you have any of these items:
  1. drivers side rear door quarter window?
  2. drivers side rear tailight
  3. grey rubberized carpeting that goes over interior rear wheel wells
Hi - do you have a set of the stereo mounting brackets?
