vin number and ordering a key !
Hello, have a few suggestions: have a locksmith make a new key, you may need to pull the ignition, if you don"t want to do that you could hot wire it to take to the locksmith and to drive in the meantime, or get a new ignition and install, that may not be a bad idea, at Cruise Moab years ago my '66 FJ45LV was having starting issues, it was a worn out connection in the ignition. Replacing would solve the key issue and any future concern on start switch failure. If you need help with hot wiring, PM me.
Best regards,
Eric C.
Fort Collins, CO
I LOST my key to my 78fj45, looked everywhere !
So I have my vin and called the local dealer. They said the vin I gave is too short !
Any suggestions ?
PM sent ....................
Thanks @samatulich :)
Thought the number on the right door lock was used to cut a keys. Have to pull the lock to find the number. Earlier was on the face of the lock. Thinking in 75 when the door changed and locke was added to the passenger's side it was on the right side still Japan is RHD so be on the driver's door.
