Vibration solved......almost.
Your wisdom please.
Vehicle: 1997 LX450, 4" old man emu, ARB front bumper.....otherwise stock
Vibration details: Would buzz/vibrate at 60-70 mph, especially upon acceleration & deceleration. Enough to really drive you nuts if you drove over 50 miles at highway speeds.
Diagnosed: Finally had enough and needed to fix. Pulled front drive line and drove.... NO VIBRATION!
What to do: I am taking it to a drive line shop to have OEM u=joints installed (even though currnt u-joints seem ok) and balanced. Drive line is stock and when removed it was out of phase.
Question: Should I have shop keep it "out of phase"or "in phase"?
-thanks
It should remain out of phase but due to the lift you may need a double cardon shaft due to the exaggerated angle of the transfer case flange. I'm in the same boat and was advised to try the front shaft in phase to eliminate that GrRRrR sound. I ended up buying 2x DC shafts because my splines were worn on both shafts.
There is a reason why Slee includes a DC front shaft in their 4" and 6" lift kits. I'm at a solid 4" with 850J's and a 1" spacer up front. Had vibes, broke out the wallet and bought a custom DC shaft, no more vibes. Very near to zero angle at the front pinion is a requirement for this to work. Cheers
-thanks
Impossible to say, the shaft geometry has changed from stock. Try both, whatever runs smoothest is best for joint life and occupant comfort.
I just talked with these folks: Curtis Tatton West Valley City, Utah Phone 801 685 0056, & said he is in the middle of a group buy and price would be $300.00 shipped for a dc drive -line. This is the route I am taking. I will update once installed.
-thanks
-thanks
That's the route I took. Curtis is a great guy to deal with.
SOLVED!!!!! Installed front DC shaft from Curtis Tatton West Valley City, Utah Phone 801 685 0056. Problem solved! No more annoying vibration/buzz at highway speeds. I am happy, happy, happy!:)
thanks for the thread.
i have the same problem as the op. j front springs / heavies in the back with both L shocks and an ARB bull bar with a winch. the only difference is that i have a 3" drop brackets from Man Fre. I just placed an order to Curtis for the front DS. im hoping that this fixes the problem. i just want this vibrations to go away. i luv this truck.
Congratulations, good to see a quick fix.
