Did some searching last night after joining and found this post https://forum.ih8mud.com/showthread.php?t=156517 by long duck dong. This is the vehicle I just purchased from him, but he did not have any replies.
In any event, the noise/vibration/condition occurs constantly above 50mph and gets worse as speed increases. I made the 90 mile drive from Albertville to Birmingham and here are the symptoms.
- does not make the noise below 50mph
- does not matter if OD is on or off, nor does it matter if the ECT/power button is engaged or not
- the noise goes away above 50 if you let off the pedal and coast
- the noise also goes away if you get in the gas aggressively, but returns once you maintain a constant speed (again >50)
- it seems to originate from the rear; didn't notice any steering shimmy
I've googled the issue and found responses that vary from out of balance tires to bad U-joints to alignment/toe issues. My main concern is that it is a rear-end/differential or tranny issue.
Thought I would rely on this site's expertise and experience so if I do take it to a shop, I'll be better prepared.
Let me know if you need further info or explanation.
Many thanks in advance!
Ben
Ben
