Vibration Puzzle
AussieHJCruza
Supporting Vendor
New South Wales, Australia
Website
www.completecruisers.com.au
Good Evening,
I have searched but can't seem to find anything quite like this, so...
I am getting a vibration somewhere in the driveline upon cruise at 1800-2200 rpm mark in any gear, or upon deceleration at those rpms too (as in, feet off all pedals)
As soon as I touch throttle or brake it seems to go, and it seems to continue if I put the clutch in.
I have had a slight vibration since I did my lift, in these circumstances but always just put it down to poor pinion angle and assumed it would go away when I got more Caster. I now have 2.4ish degrees Caster angle.
Th vibration got bad after I put new genuine chassis-radius arm bushes and 3 degree rubber Caster bushes in (from 2 degree) and the day before this I hs it dyno tuned and I suspect the operator didn't pull the front driveshaft and let th centre diff do all the work. I don't believe I have the viscous coupler as it is a 92 build 93 model year.
My first thought was uni joints, but it doesn't seem quite right for that as I thought a uni progressively got worse as speed increased. Has something been stuffed in the transfer or what? I can't quite work out what it could be.
Try greasing one location at a time on the driveshafts just to eliminate them from the possibilities. Cheap, easy, and quick to do. Don't do them all at once or you will want to fix everything instead of one thing if it makes a difference.
Like Inkpot said - cheaper first.
If that doesn't help, pinion angle out back can be a wildcard for vibes - or if your lift is big (based on sig tire size, I'm guessing <3" though, right?) - sometimes needing a DC driveshaft up front solves it.
But yes, esp if you haven't done joints or greased yet - start there.
Lift is a 2" h/d, so sits around the 2.5 to 3" mark
Motor mounts...
