Vibration in AC compressor rotor
Knoxville
When I've got the AC on and the compressor kicks in, the rotor (the think the belt runs around) on the end of the compressor has and wobble and noise to it.
I've checked the viewing glass with the AC on full blast, and it has bubbles swirling in it, which the FSM says is an indication of insufficient charge, but didn't think that would result in this wobble.
Have any of you had this before? Thoughts?
TIA.
Rookie2
It's called a pulley. You need to get under the hood ASAP and see if the pulley is loose on the shaft or if the shaft itself is loose in the compressor from worn bearings. If it's only doing it with the compressor engaged, that unfortunately sounds like bearings to me, but regardless, get it figured out before it gets any worse.
I suppose maybe low refrigerant could have starved the compressor of oil, leading to worn bearings?? But really, just focus on the pulley itself at this point.
Good luck,
Curtis
Rotor is how they label it in the FSM diagram, but your terminology makes more sense.
Any suggestions on how to tell which is loose? I presume loosening the drive belt and see if the pulley wiggles?
Thanks,
Rookie2
Thanks,
Rookie2
That should do it. See if the pulley is wiggling on the shaft or the shaft is wiggling in the compressor, or...
Keep us posted; I'm curious what's up.
Good luck,
Curtis
There is a bearing inside of it that rides on the compressor nose. Does it do it all the time or only with the A/C on?
You can remove the belt to get the tension off of it and see if it rocks or not.
There is some slight metallic noise coming from the end of the compressor when the AC is off. That particular noise doesn't really seem get worse when the AC is on, but then when the AC is on, I get the slight wobble and the noise associated with it. Don't know how to really explain that noise, but it's kind of what you'd expect from something that is wobbling, not real loud... just an out of balance vibration noise.
I'll see if I can loosen the belt up and wiggle on it when I get home in a bit.
Thanks,
Rookie2
It sounds like the clutch may be starting to fail. Do look into it soon. The clutch bearing could take out the compressor nose, requiring you to replace both. If you remove the belt and find the pulley to be loose and rocking, I would suggest you do not put the belt back on until you investigate further. You can drive it with the belt off and there is no problem. If you do drive it like that, be sure to tighten up the bolts on the idler so it won't fall off...;)
Okay, removed the belt and the pulley is loose. I can wiggle it back and forth a bit.
I'll go look at it some more, but any thoughts on what could cause a loose pulley and how to fix?
Thanks guys.
Rookie2
Worn bearing or bad compressor nose.
If it's the bearing, you replace the clutch. If it's the compressor nose, you replace the compressor. Usually the clutch takes out the compressor if you do not catch it early enough.
Okay, looks like I need to remove it and take it apart. Last question for now, I'm having trouble figuring out which part is the clutch. The FSM talks about it, but doesn't have anything identified as "clutch" in their diagram. It's not the thing they identify as strator is it?
Thanks again,
Rookie2
Has anyone here ever removed the pressure plate on the compressor, and have any suggestions regarding the need or lack of need for the two special service tools indentified in the FSM?
Thanks,
Rookie2
Thanks,
Rookie2
Hey Rookie2,
I just did this last week on my '84 Cressida (my stator was bad); probably not exactly the same but hopefully similar.
The "magnetic clutch" consists of the pressure plate, the rotor (what I was admittedly calling the pulley), the stator (an electromagnet, I believe) and all the associated bearings, washers, etc.
First of all, are you sure the rotor's wiggling on its bearings, but that the shaft itself (grab it fom in front of the pressure plate) is not loose?? If the shaft is loose in the compressor, you're probably better off just pulling the compressor rather than doing what follows:
Removing the magnetic clutch:
The first SST referred to is probably to keep the pressure plate from rotating while you loosen the nut holding it in place; I used a big plumber's pipe wrench on the rim of the plate for this step. The second one is most likely just a custom set of snap ring pliers; get a good set from Sears or somewhere like that. (NOT Harbor Tools.) Make sure they're for "external" snap rings, and choose ones with removable bits at various angles. (Removing those rings was the only frustrating part for me; just be patient and thoughtful about how they work.)
The rotor is the part with the bearings. Hopefully (as in lesser of two evils) you'll find those bearings are shot (if they're not they should be very smooth) and you don't need to go any further.
Good luck!
Curtis
Curtis,
First off, thanks for your time and response to this thread. It doesn't appear to be an area many folks have dealt with.
You're right on the first SST, but the second one is actually a screw looking thing that goes into the center of the pressure plate to press it off the end of the compressor. Looks like you hold the pressure plate with the first SST (or a big wrench, or maybe some chain pliers) and remove the existing screw, then replace it with this SST screw that appears to be unthreaded over a portion of the end. Anyways I'm assuming this SST screw is longer and when you screw it in it pushes against something to pressed the pressure plate off the end of the compressor.
I've grabbed the pressure plate, and there's no movement there. It's just the pulley. I can grab it with my fingers and wiggle it back and forth about a 1/16".
Thanks,
Rookie2
Rookie2 said:
Curtis,
Oh yeah, totally forgot about that one! :doh: To get around that one I just *gently* pried between the pressure plate and the rotor with a screwdriver (or maybe one on each side?) and slowly worked it off.
Look further in the instructions and you'll probably see the snap-ring pliers, no?
In short, no, I didn't use any special tools.
Sounds like you're good to go; dig in!!
Curtis
Well, got the pressure plate off along with the rotor/bearing assembly. The bearings roll smooth. The play is between the interface of the rotor/bearing assembly and the compressor shaft. You can slide it on the shaft and just wiggle it back and forth. It looks to me like the compressor is made of a softer metal such as aluminum. I'm wondering if the shaft on the compressor has somehow beam compressed by this progressively worse wobble, to create this slop.
Not sure where to go from here. Could be a new compressor. Any more suggestions/thoughts?
Thanks,
Rookie2
Anybody have experiences with remanufactured OEM compressors? I hate to drop a full bucket of cash on this..., I'm one of those guys that uses my AC about 10 times a year primarily for the comfort of passengers.
:beer:
Rookie2
