Vexed by O2 sensor
‘05 100 series
-P0136 code
-Replace the B1S2 sensor with an OEM sensor. Still reading 0 volts on the scanner.
-Wires aren’t frayed
- Can’t find if there’s an O2 sensor fuse (any inisght appreciated)
-All under hood fuses are good - have not jumped into the inside fuses because they are a pita to get at
-Got an EVA code on the scanner as well, but I’m chalking it up to A rusty filler neck (how the hell does that even happen - because none of the 70’s cruiser i have have that issue), plus don't think those EVA and O2S on the scanner are linked.
Any suggestions, I’m stumped, but I’m not that smart so I’m easily fooled.
Thanks
I have a PO155 code at the moment.
Did your VSC OFF and VSC TRC amber dash lights come on at the same time? Mine have unless thats a separate issue which I assume it is.
I havent read the voltage on my scanner yet though as its literally day 1 of this for me.
Have you made any progress?
Per the FSM: "If the ECU stores DTC, VSC TRAC warning light and VSC OFF indicator light is ON."
The P0155 code is right-hand front O2 sensor.
