Very hot oil
Williams Lake B.C.
Just went out to fire up my 78 45this morning. I put an oil pan heater on it and plugged it in for the first time last night. it was -15C last night. It had the oil bubbling away. Sounded like something cooking on the stove. I've got one on my HJ and it sure doesn't sound like this. They're both 500w but I'm worried I'm going to screw something up with the oil getting that hot. What do you think? pete
Pete:
Certainly no expert on an oil heater but I really cannot believe that your oil would be at a boiling point i.e. bubbling. That would mean some serious heat i.e. heat that far surpasses vigorous engine temps. How do you know it was the oil and not some other sound?
What type oil do you run?
Did you touch the oil pan to see if it was too hot?
I seem to recall having this happen to me, sometime back in the 70s. Faulty heater. High resistance=high heat.
I think I'd just switch heaters between the vehicles and see if the same thing happens, or reverses, or whatever. If it isn't a big project. Those just attach by magnets, right?
My turkey fryer gets to over 400* without "boilong" the oil..
Sounds like something else might be in there...
The heater might have a hot spot - a spot that is hotter than its supposed to be. Even though its supposed to be 500W, you might find that its drawing more current than its supposed to. As for resistance - more resistance usually means less heat as opposed to a short which is very low resistance which leads to too much heat.
I know nothing about electricity. So, I'm sure 60wag is correct. :D
plugged both heaters in when I got home yesterday and the one on the 45 is way hotter.I can hold my finger to the other one but not this one. It is actually bubbling the oil in the pan.ouch!They're strapped to the pans so I think I'll put a spacer between the pan and hot one but now I'm curious about oil temps. What temp would the oil normally be when running and also what is it's boiling point. Thanks for the help guys. pete
Wow, that does not sound right. If it's getting up to oil's boiling point, I would seriously thing about getting a different heater out of fear of fire (doesn't paper and such combust at 451 degrees?).
From the way it sounds, you have a defective heater. I wouldn't leave it on your truck, because there is probably a short in there, and you don't want to wake up with a smoldering pile of 25 y/o steel in your garage one morning.
and don't forget that the oil in fact disintegrates at such temperatures. take the heater off, and change the oil twice.
