Alright, I am very close to having the engine pulled out of the LX. I was thinking a few things:
1. Should I go ahead and take out the AC condenser and the brackets? I could take the engine trans out as a unit. It seems easy enough. Remove the lines, bag and tag the ends to keep it clean and it should be good. It would also help with access to the steering components and minimize risk to the condenser that is only protected by a piece of cardboard.
2. How much cooling capacity is in the trans cooler? Can I remove the lines to the radiator? I would like to install an all aluminum radiator and the manual ones are a lot cheaper anyway.
3. I was actually surprised that the power steering doesn't have a cooler. There is just a cooling loop sans fins, bolted to the front crossmemeber. Should I add a cooler?
4. I am going to get a new engine harness. I was thinking of cutting it and adding some connectors for the stuff that goes to the trans and o2 sensors so I wouldn't have to take those out if I had to pull the motor again. (My friends have called me captain overkill many times so just slap me if I am overthinking this and being stupid.)
5. The throttle cable isn't sticky but the outer protective cover is coming off. should I replace it?
Thanks in Advance for any advice.
Condenser clear. Nearly time to break out the hoist.
