valvetrain noise @ cold startup
The valves are making noise in my rig at cold startup in the morning. It's not noisy when the motor is warm, and I didn't notice it last week when it was warmer. I changed oil back in Nov and used 5W40 Mobil-1. It's the first time I used synthetic since the rebuild 7k miles ago, and the first time I have ever used 5W40. Curiously enough the startup rattle has reduced somewhat.
I'm wondering if the oil is too thin. Ambient temp is high around 30F and low around 20F.
I'm going to check clearances. The manual doesn't make any mention of it, but I wonder if there is a cold temp spec for checking the clearances.
Eric
my truck does this too for 1 second at cold start up and then quiets down.
anyone have any insight into this? is this even an issue or should i just forget about it?
You won't find an oil "too thin" for cold startups. If you're getting a lot of top-end noise on cold startup (caused by lack of oil flow), I'd switch to an oil that is "thinner" at lower temps. For instance, if you're running 10W40 now, try 0W40 and see if it improves. They both flow the same at operating temp, but the latter is far superior to the former due to its better lubrication on cold startups. Hope this helps.
Do a search on startup rattle, it’s a characteristic of the 1FZ motor. The timing chain tensioner is hydraulic and the leading theory is that it takes a second for the oil pressure to get there and the chain rattles for a second or so on cold startup. Many motors have been doing it for years without issue. The rattle in mine was greatly reduced by switching to the smaller oil filter, then almost eliminated when I switched to the thicker oil recommended on the international chart.
Eric
I would consider a new oil filter and/or a different brand of oil filter.
Toyota brand filters are always the best bet.
If the anti-drainback valve in the filter is not working, or if the filter does not have one, everytime you start the engine, no oil gets
to the valve train until after the filter is pumped back up with oil.
I have found that this happens with all filters the longer you keep
them on; in my experience around 5-7,000 miles.
ie: it all drains back into the oil pan while the car is sitting in your driveway.
There are a few companies that make "long life" filters,
Mobil 1 makes one but I do not have any experience with them.
G
I think you may be off on your suggestion. In a 10w40 oil, the oil will "weigh" 40 at startup and 10 when hot. Oil gets thinner as it gets hot. Put your favorite oil in a sauce pan on the stove, cook it, and watch it get thinner to prove this. That said, a thinner oil at startup would be something like 10w30.
No sir, you've got it backwards. Cary explains it perfectly in this thread: https://forum.ih8mud.com/showthread.php?t=178140
The first number in an oil weight refers to the cold temperature pumping test the oil has passed. The lower the first number the lower temp pumping test that has passed.
The second number refers to the thickness of the oil at 100c. 30 weight oils are about 9.5-12.5cst @100c, 40 weight 12.6 to 17.5, and 50 weight 17.5 to 22 or so.
There is no relationship between the two numbers.
When we refer to a "light" 40 weight oil, we mean an oil like Mobil 1 0w-40 that is about 14cst @ 100c. The sweet spot for most cars on oil appears to be the heavy 30 weight oils/light 40 weight oils that meet ACEA A3. These oils minimize wear while maintaining reasonable pumping losses."
:cheers:
:cheers:
Sorry if my advice was wrong. I was simply using logic. I figured if a gear oil was something like 75w90 and gear oil is thicker than motor oil than that tells us that as the numbers get higher, the oil is thicker. That combined with the 'oil in the sauce pan' I mentioned is how I came up with my suggestion. Based on this, I still dont understand how it could be the opposite but Im not certain so I wont argue it. Thats why initially I said "I think"...:beer:
