Extemely low oil pressure at times?
Colorado m'fing Springs!
Im still in the discovery phase of what the hell is going on as this just started happening over the past week. I know the oil pressure gauge fluctuates at different rpm's and have gotten used to that, this is different.
Startup OP is normal and during warm up the levels seem normal. Once warm is when the gremlins come out. The gauge will drop slowly and keep dropping past the last line almost into the dead zone at two times:
when coasting and deccelerating from 50 and below OR
maintaining a steedy rpm of 1500-2000 rpm
Also i was thinking of some kind of blockage or pickup tube problems because if brake hard when the gauge has dropped extremely low, the level will raise as i deccelerate.
Some other info that might be relevent:
-94m lc with 165k
*Running rotella 30w, previously ran Valvoline 60w Did this because a mechanic reccomended this due to cold startup would get sounds like rod knock for about 2-4 seconds... he said this was oil pressure building??? Noise during startup did go away, but switched to Rot 30w because i didnt like the idea of straight 60w. Any input on this alone would be good.
-currently on first couple hundred miles of AutoRX engine treatment. Highly revered on www.bobistheoilguy.com
Whoo, long post. Need a brew after that:beer:
OK, I think you need to clarify a few things here..
Your mechanic recommended you run a straight 60W oil? And this was because of rod-knock like sounds during cold startup? :confused:
So you switched to a 60W oil and the noise went away? Then you went back to a 30W and the noise is back?
I think a fresh oil pump, some 0W40, and a mechanic worth his weight in dog s*** would be a good start.
Before you do anything hook up a mechanical gauge and see what the pressure really is. My guess is that it is normal. If it isn't, your motor is about to self distruct anyway.
The senders go bad, the connection gets funky, anything can be wrong with it. The point is, the first step in troubleshooting is an accurate measurment of the pressure.
A couple key bits of information in your description; ie: that the pressure was OK with 60W and very low with 30W; but that the oil pressure needle did move to the normal range when cold.
That tells me you may have worn internal parts; either the pump is worn, so it can't keep the pressure
up once the oil gets to operating temp, and/or the main bearings are worn.
I would put a quart of RISLONE in it, run that for a couple hundred miles, then add an Engine Flush product just before you change the oil and let it run for 5 minutes, and thendrain it very well;
that should get rid of any gunk, crud, varnish, whatever;
then add a high quality 10W-30 oil and use a Toyota oil filter. No other additives are needed;
they just dilute the oil and mess up the chemistry the oil engineers (Tribologists) brewed into
the oil.
I would not use a 0-40 oil. Use a 10W-30 or 10W-40 if you live in a desert, but not a 0 anything unless you live in Alaska and it is winter.
After all that, if the pressure is still reading in the high range when the engine is first started, but then drops to below the first line, you probably have worn parts; IMHO.
g
I would not put any "mechanic in a can" products in your motor. They won't change anything.
The above advice about 0w-40 is misinformation. It's 40 weight viscosity at operating temperature and provides very low wear in the 1FZ motor as has been shown in numerous oil analysis readings posted on this board.
You may in fact have worn parts, or you may be chasing bad sensor readings. you won't know until you get an accurate measurment and check against the specs in the FSM. (Which is 37 psi or more at 3000 RPM).
This is the first I've heard of 60 weight in a 1FZ, though I personally run 15w-50 most of the time. Here are oil weights I have run in the past 9 years with no issues:
5w-30 Dealer bulk juice
10w-30 Penzoil Synthetic
0w-40 Mobil1
5w-40 Delvac1
15w-50 Mobil1
15w-40 Chevron Delo
g
Please explain why he shouldn't use a 0w-40 oil, inquiring minds want to know. :rolleyes:
To Cruiserdrew
I would not call my advice regarding the use of 0W-40 as misinformation,
I would call it an opinion, just as anyone else's posts on these forums are.
I have owned LC's and have driven LC's all over the world, and have never seen anyone recommend a 0W-40 in a LC, nor have I seen it recommended in any Toyota manuals,etc.
I also have tried virtually every brand and weight of oil over the last 40 years,
but I have always come back to 10W-30 Mobil 1 (for 20 years;now High Mileage type) as the best all around choice; Period.
The main point of the original post was low oil pressure and how to work through the problem
on your own.
To Cruiserdrew
It's your opinion, and it's also misinformation. Why? because the following is not just an opinion, it is fact backed up by data accumulated on this board:
gray,
WTF is going on??
You've been a member since 2005, and suddenly you've had diarrhea of the keyboard for the last two days, tossing up these stream-of-consciousness posts with no regard for the ongoing collective wisdom of this board, which is its primary reason for existence.
What gives???
Curtis
To Cruiserdrew
on your own.
You are long on opinion but short on facts. I asked you to explain about why 0w-40 is too thin, you haven't except to throw out an opinion that has no support.
I have explained this about 100+ times over the years, but apparently in you two years here, you have never read an oil thread or the FAQ. Rather than retype it for the 101 time, here is exactly what was posted explaining it for the 100th time about two weeks ago:
"Argh!!!! We go through this about every 2 weeks.
The first number in an oil weight refers to the cold temperature pumping test the oil has passed. The lower the first number the lower temp pumping test that has passed.
The second number refers to the thickness of the oil at 100c. 30 weight oils are about 9.5-12.5cst @100c, 40 weight 12.6 to 17.5, and 50 weight 17.5 to 22 or so.
There is no relationship between the two numbers.
When we refer to a "light" 40 weight oil, we mean an oil like Mobil 1 0w-40 that is about 14cst @ 100c. The sweet spot for most cars on oil appears to be the heavy 30 weight oils/light 40 weight oils that meet ACEA A3. These oils minimize wear while maintaining reasonable pumping losses."
What ever it is STOP!! STOP!! STOP!
Bj70 Alex might can tell you better than me about the oil pumps something about a common separation :confused::confused:
any more operation may/will cause damage!!
Seems to be more oil viscosity facts going around than you possibly causing more expensive damage by continuing...
II had a similar thing happen when I tried off brand 5w-30 oil.
I would be driving down the interstate and notice the oil pressure guage was way down.
When I went back to Premium grade 5w-30 oil the pressure drop thing went away.
I do get the "Rod-Knock" noise at start-up.
gray,
WTF is going on??
What gives???
Curtis
I am a bit surprized at the personal attacks by some on this board.
I am just giving my opinion; I am not a mechanic, just an old
guy who has owned Landcruisers for almost 30 years and other cars for
another 10.
Diarrhea? stream of consciousness? no regard for the "collective wisdom:
I did not realize that opinions other than the "collective wisdom"
were not allowed.
I also did not realize that there was some required break-in period
or test to pass in order to post comments, or required number
of posts in order to be accepted.
Guess I missed that part.
Collective wisdom is another word for socialism;
ie: only the self-appointed elite know the truth.
I stand by my opinion on oils for LC's based on my personal experience, and would not use a 0 weight oil unless I lived
in a cold enviroment.
I do know that 0w indicates the viscosity of the oil at 0 degrees and the 40W is the weight at operating temperature, 200 degrees.
Nowhere in any Toyota manual do they recommend 0W-40
for a LC that I have seen.
I trust the Toyota engineers more than any invisible "expert"
on the internet.
The original thread was about very very low oil
pressure, not about which oil is best.
I have used 5W-30 and 10w-30 Mobil 1 for 25 years
on an FJ-60, FJ-62(280K), and an FZJ-80(240K) with absolutely
no oil/wear related problems; never had the engines apart,
no oil use, no smoking, perfect spark plugs (not oil fouled) after 90K miles, etc,etc,etc.
I have also driven LC's in half a dozen countries, including Iraq, really, and we would never consider using a 0W oil where the
ambient temp can get up to 140 degrees, or in Florida for that matter.
Whatever.
How about this; I say you guys win the argument,
and I go out and buy a new 2008 LC in a month.
Whatever.
The attack is on you spreading misinformation that you espouse as your "opinion" when it flies directly in the face of facts.
Overseas Toyota recommends the use of 40 weight and even 50 weight oils. Rather ironically, you are standing there saying that in hot weather you would rather use a thinner oil, than a thicker one (0w-40 is a 40 weight oil).
Toyota does not list 0w-40 oils in their manual, because they weren't being sold in the the early 1990's.
You are incorrect about the cold pumping test, to pass the 0w test, the oil is tested at -30c. The thickness of oils at operating temperature is tested at 212f, not 200f. A 30 weight oil is 9.2-12.4 cst @ 100c, a 40 weight is 12.5 - approx 17.4 cst @ 100c, it doesn't matter if they pass the 0w, 5w, 10w, 15w, 20w, 25w, or are a "straight weight" oil. THOSE ARE FACTS.
Finally, because you are wrong, you are going to guy buy a 2008LC?!!! WTF does that have to do with anything?
-94m lc with 165k
I am responding to the original thread, not debating oil specs
as some people seem to be fixated on.
Change your oil to a high quality oil; like Valvoline Max-LIfe 10W-40 and put in a new Toyota filter and then see what it does.
I just go on my 40 years experience with what works. Mobil 1 5W-30 on a newer engine,
Mobil 1 10W-30 High Milieage on an older engine to decrease weepy seals, etc, and maximize gas mileage.
I repeat, I have used Mobil 1 5W-30 or 10W-30 in LC's as long as it has been around; and it works.
My opinion is that 40W for the average driver does not offer any significant advantages (in a sound engine) and may decrease gas mileage and acceleration, which is what I experienced (hence I have an opinion) in my LC's.
The higher viscosity would be of benefit in a worn engine; I have used Valvoline Max-life 10W-40 Full synthetic, but came back to Mobil 1 10W-30; it just worked better, because it is better.
If we were publishing research in a prestigious scientific journal dealing with TRIBOLOGY
then we would be in another forum, not a forum for the average guy working on his LC in
his driveway.
You are obviously the oil viscosity god (or at least know how to surf the net).
I am just a physician, and occasionally I'll see patients who obsess on various things just
to prove that they are right to the point of exhaustion. Like the guy who went to jail because he didn't want to pay a 50 cent toll.
Life is too short to waste it getting stuck in the weeds.
Now, can we agree to let it go?
Gray-As a physician, maybe you can agree that the state of the art advances over time. Oils get better too, and 0w-40 is just about the best of the lot. Remember, Mobil could choose to label it as 10w-40 because it would also meet that spec. It also happens to meet an even better spec and will allow starting at very low temps, while still meeting a 40w viscosity standard at operating temps. This extended range is very helpful for someone like me who lives in a hot climate, but travels frequently to a cold one--Lake Tahoe in the winter.
In Australia, the preferred oil for the 1FZ motor is 20w-50, I believe. The point is that the motor will tolerate a wide range of operating viscosities, and 30w oils may be dictated by government economy standards in the USA as opposed to absolute minimum wear requirements. I wish I could remember where the oil viscosity chart from Australia was posted, but I think the upper limit for 30w oils was 90F ambient temps.
I am not concerned enough about wear to run oil analysis tests myself, but I have run 0w-40 on numerous occasions over the years in my 80 series. It is nice to see that experience backed up by actual data that Cary and others post on the forum. There is even data posted by Raven Tai where he had very low wear numbers with 15w-50 Mobil1--good to see that too, since I run that most of the year.
To get back to the topic of the original poster---I would drain the 60 weight for sure. I would recommend a run of 15w-40 Heavy Duty oil. (Chevron Delo at Costco is a great deal) Why? Because it's cheap, and he is likely to be doing several changes to sort out his problems. 15w-40 will work perfectly down to 10 degrees F, and has a robust additive package that may aid in cleaning his motor-without resorting to flushes. and other mystery products like Risoline or Sea Foam. He still needs to know his pressure, because if it's normal that rules out a whole bunch of quickly terminal engine problems.
Gray-I'm not attacking you at all, just pointing out that you were wrong, so that others don't take your post as fact. You and I can both agree that Mobil1 is a great product, and will make your Land Cruiser run a long, long time.
