Valvetrain Help
Palmdale, CA
Hey guys, blew the HG in my 80 on my birthday back on Sept 8th. Started taking it apart and I've gotten pretty far. One issue I have is with the rocker bolts. I cracked them loose in the correct order but the bolt circled below is very tight. I wasn't able to get it up jas high as the other bolt on cyl 2 because I'm afraid of snapping it. What else can I do to free it up? Is heating it up an option?
Thanks for reading!
yes,all the other bolts loosened with out issue.
That indicates debris on it from the cooling system, typically stop leak and such. Screw it in, back it out, screw it in, back it out. Do it over and over, shooting for about 1/2 turn more each time coming out. do NOT force it. You don't want to twist it off or strip the threads in the block.
Screw it in a few turns, then soak the shaft with PB blaster, wait 15 minutes, then try to unscrew again. The idea is to get some lube on the threads inside the block. Do this multiple times and do NOT get in a hurry.
Thanks! I already began hitting it with some lube but decided to quit while ahead haha. Will get back to it later today and report back!
Is it possible to remove the head without removing the rocker arm assembly? I think this bolt is gonna stop me dead in my tracks. 🤦🏽‍♂️
I'm not familiar with the 3FE so take this with a grain of salt. I would reinstall (snug) any other bolts that have been removed then try removing the problem bolt first. The problem bolt may be binding because of the spring pressure on some of the valves. Also before starting the removal process did you follow the FSM procedure for positioning the crank/can?
I would spray the bolt with some liquid wrench penetrating fluid and very softly tap the bolt repeatedly with a small brass hammer or something. Tapping the bolt will vibrate the penetrating oil into the threads. Do this multiple times and work the bolt in and out a bunch after soaking with the fluid.
I’ve been waiting on a friend to come help me lift this head off. Just pulled the water pump and...
I’m gonna assume I should replace the head altogether. Are the heads even available?
Have it hot tanked when the shop checks and machines it.
Heads are not junk unless they are cracked.
Yea, the rust. Not seen in the picture but there’s bits missing in there lol. I will get it checked out but seeing that kinda discouraged me a bit 🤷🏽‍♂️
Internal casting is gonna look rusty and rough. Its not machined. Every cast head ever is gonna look similar to that. Have the head surface checked, check for cracks, and have them check valves/seats — while its off.
Got the rocker assembly of a few days back. Turns out the bolt I had trouble with has a shoulder. Odd, considering the other bolt didn’t.
Hello guys, sent the head off to the machine shop on Friday. I should have info by the end of the day tomorrow and will decied what needs to be done. Can someone post a picture and info regarding the drilling and tapping of the 3fe head? I'd like to explain it to the machinist the next time I speak with him.
Thanks!
Here's a link with photos: post #8
@slow95z may have a replacement head or a complete engine for a 3FE.
