Valve cover goo??
SE Iowa
Any ideas on what might have caused this? 1974 F engine, was running really rich a while ago, but I think I have that fixed now. At the time, the oil reeked of fuel, so I replaced ignition (OEM stuff), adjusted the carb, retimed and changed the oil. I don't smell gas in the oil anymore, but when I pulled the cover to adjust the valves, this is what I found. Thanks in advance for the ideas.
Tony
Or, it might be just condensation, high humidity, cool temps, and a plugged PCV valve.
Yeah, I did get the valve cover. Looks like it will fit perfect. Thanks. BTW, what year what that off of? Just in case I have to replace gaskets down the line.
Condensation seems to be the general thought here, too. I really don't run it hard enough yet to drive the water out. It's not quite legal to drive on the road yet, but getting close. Should I be concerned about it just yet? My Dad suggested maybe doing the old kerosene trick to clean everything out and maybe switching to straight weight oil for the summer as he says it has less detergent in it than multi-viscosity oil does?
Tony
The oil's fuel scent could have been from poor tune, but if it still stinks like fuel at the next oil change, it's time for a new fuel pump. Small cracks in the pump diaphrams let fuel escape into your crankcase.
The fuel pump idea has popped into my head before. I don't smell much gas at all now, though. The ignition was bad enough that it was missing on one cylinder about half of the time and dumping raw fuel into the cylinder. OEM components fixed that. I will keep that in mind, though.
I've been messing with this thing for about three years now, just working on it when I have time. I'm in the country, so I can run it up and down backroads, but I don't quite trust it yet (or my abilities sometimes!!). It gets maybe 10-15 minutes at a time once a week or so, and spent all winter in my garage. If it warmed up at all, the cement floor would sweat with condensation, and it did not get run much last winter. All things considered, she runs pretty good, and getting better as I learn more all the time. Shows 120-130 psi on all cylinders, which I know is kind of low, but like I said, runs good.
I am going to replace the PCV today, and see if that helps in the long run. A PCV valve should rattle, I know, but how much pressure should it take to get the check valve inside to release? It seems to stick for a bit before it turns loose. BTW, I found the same residue at the PCV inlet to the crankcase.
Tony
I forgot, my coolant was a little low, but I also have a slight leak at the water pump gasket that I have not addressed as of yet. With compression numbers like I said, is there still a possibility of a head gasket problem?
Tony
I'd recommend you do a vacuum test to evaluate for head gasket issues.
